Connect to mobile phones, GPS systems, PDAs, OTG devices and digital cameras by using the micro-USB connection on your computer or other USB device. The micro-USB connector is smaller and thinner than the previous USB Mini-b standard while offering better performance. Its small right angle form factor is ideal for today's compact portable devices while easily transferring data or charging your device at a transfer speed up to 480 Mbps. This cable is compliant with USB 2.0 specifications and the On-The-Go supplement.
- C2G USB 2.0 A Right Angle to Micro-USB B Right Angle Cable - USB cable - 2 m
- USB cable
- 90° connector, right-angled connector, sync and charge, USB On-The-Go
- Length
- 2 m
- Connector
- 5 pin Micro-USB Type B - male
- Connector (Second End)
- 4 pin USB Type A - male
- Black
- Limited lifetime warranty
- USB cable
- Length
- 2 m
- Black
- Connector
