Make your work environment more flexible and efficient. This heavy duty 17AWG cord is designed to work with PDUs, PSUs and other high power devices that use the 3-pin male-to-female shroud power connector. Plus it features a fully moulded design for maximum durability and long life. The female connector plugs directly into the device while the male connector plugs into another power cord, or auxiliary power port on power supply for auto power when the system is turned on.
Product Use
Power cord for high current IT appliances -
Warranty Details
This product carries a lifetime warranty -
Connector Information
- C2G 17 AWG 250 Volt 16 Amp Power Cord - power cable - IEC 60320 C19 to BS 1363 - 2 m
- Power cable
- Molded
- Length
- 2 m
- Localisation
- United Kingdom
- Connector
- Power IEC 60320 C19
- Connector (Second End)
- Power BS 1363 - male
- Rated Voltage
- AC 250 V
- Black
- Limited lifetime warranty
- Power cable
- American Wire Gauge (AWG)
- 17
- Rated Voltage
- AC 250 V
- Molded
- Length
- 2 m
- Black
- Localisation
- United Kingdom
- Connector
