Product
C2G 2m UK 17AWG 250V 16 Amp Power Cord BS 1363 to IEC 60320 C19
Quicklinx: 98PYWS00 Mfr#: 80626
Length: 2m
£6.71 ex VAT
£8.05 inc VAT
Make your work environment more flexible and efficient. This heavy duty 17AWG cord is designed to work with PDUs, PSUs and other high power devices that use the 3-pin male-to-female shroud power connector. Plus it features a fully moulded design for maximum durability and long life. The female connector plugs directly into the device while the male connector plugs into another power cord, or auxiliary power port on power supply for auto power when the system is turned on.
  • Product Use
    Power cord for high current IT appliances
  • Warranty Details
    This product carries a lifetime warranty
  • Connector Information
C2G 17 AWG 250 Volt 16 Amp Power Cord - power cable - 2 m
Power cable
Molded
Length
2 m
United Kingdom
Connector
Power IEC 60320 C19
Connector (Second End)
Power BS 1363 - male
Rated Voltage
AC 250 V
Power cable
American Wire Gauge (AWG)
17
Rated Voltage
AC 250 V
Molded
Length
2 m
United Kingdom
Connector
Power IEC 60320 C19
Length: 2m
Brand: C2G
Price Range Ex VAT: 0 - 50
