This OM3 Duplex Multimode Fibre Optic Cable is ideal for connecting 10GBase-SR, 10GBase-LRM, SFP+ and QSFP+ transceivers for 10 gigabit network connections. This cable has a LSZH jacket which protects from toxic and corrosive gases in poorly ventilated spaces and other areas where it is most critical. This cable also provides backward compatibility with existing 50/125 equipment and the performance headroom required to support LED and VCSEL laser light sources, and 10 Gigabit Ethernet applications. The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures.
Warranty Details
This product carries a lifetime warranty -
Jacket Rating
The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures -
Backwards Compatible
This cable provides backward compatibility with existing 50/125 equipment
- C2G ST-ST 10Gb 50/125 OM3 Duplex Multimode PVC Fiber Optic Cable (LSZH) - network cable - 2 m - aqua
- Network cable - OM3
- Technology
- Fibre optic
- Type of Fibre Optics
- Multimode
- Halogen-free
- Length
- 2 m
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- 2 x ST multi-mode - male
- Connector (Second End)
- Aqua
- Limited lifetime warranty
- Network Cable Type
- Technology
- Fibre optic
- Multimode
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- Fibre Qty
- 2
- 50 / 125 micron
- Halogen-free
- Length
- 2 m
- Aqua
- Connector
- TIA/EIA-455-171A
- -20 °C
- 70 °C
