C2G 2m IEEE-1284 DB25 Male to MicroCentronics 36 Male Parallel Printer Cable
Quicklinx: 684GWS00 Mfr#: 81465
High-speed IEEE-1284 compliant cables from C2G ensure you realize the added speed and two way communications. This advanced technology, which defines high-speed, bi-directional communications between PC and peripheral, requires both high quality connectors and a specialized wire-type to handle the increased data rates.
C2G printer cable - 2 m
Printer cable
Double shielded twisted pair
Molded
Length
2 m
Connector
DB-25 - male
Connector (Second End)
36 PIN mini-Centronics - male
RoHS
Printer cable
Shielding Material
Foil with braid
Molded
Length
2 m
Connector
25 pin D-Sub (DB-25) - male
IEEE-1284, RoHS
