This precision-engineered cable is fully compliant with the DVI standard defined by DDWG (Digital Display Working Group). The DVI-I single link configuration provides enough bandwidth for resolutions up to 1600 x 1200 pixels and allows high speed transmission up to 4.95 Gbps. Three analogue 30 AWG coaxial lines enable high speed analogue transmission.
- C2G DVI cable - 2 m
- DVI cable - single link
- Colour-coded connectors
- Length
- 2 m
- Connector
- DVI-I - male
- Connector (Second End)
- DVI-I - male
- PC 99, RoHS
- DVI cable
- American Wire Gauge (AWG)
- 28/30
- TMDS Links
- Single link
- Plated Connector
- Gold
- Length
- 2 m
- Connector
- 18+5 pin combined DVI (Single-Link) - male
- PC 99, RoHS
