This precision-engineered cable is fully compliant with the DVI standard defined by DDWG (Digital Display Working Group). The DVI-D dual link configuration provides enough bandwidth for resolutions up to 2048 x 1536 pixels and allows high speed digital video transmission up to 9.9 Gbps. 28 AWG copper conductors are individually insulated in foam-polypropylene to minimize crosstalk, and ensure high-speed, error-free transmission.
- C2G DVI extension cable - 2 m
- DVI extension cable - dual link
- Technology
- Triple shielded
- Colour-coded connectors
- Length
- 2 m
- Connector
- DVI-D - male
- Connector (Second End)
- DVI-D - female
- PC 99, RoHS
- Technology
- Triple shielded
- Shielding Material
- Foil with braid
- American Wire Gauge (AWG)
- 28
- TMDS Links
- Dual link
- Plated Connector
- Gold
- Length
- 2 m
- Connector
- 24+1 pin digital DVI - male
- 24+1 pin digital DVI - female
- PC 99, RoHS
