C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SLWS00 Mfr#: 81194
This precision-engineered cable is fully compliant with the DVI standard defined by DDWG (Digital Display Working Group). The DVI-D dual link configuration provides enough bandwidth for resolutions up to 2048 x 1536 pixels and allows high speed digital video transmission up to 9.9 Gbps. 28 AWG copper conductors are individually insulated in foam-polypropylene to minimize crosstalk, and ensure high-speed, error-free transmission.
C2G DVI extension cable - 2 m
DVI extension cable - dual link
Triple shielded
Colour-coded connectors
Length
2 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - female
PC 99, RoHS
DVI extension cable
Triple shielded
Shielding Material
Foil with braid
American Wire Gauge (AWG)
28
TMDS Links
Dual link
Plated Connector
Gold
Length
2 m
Connector
24+1 pin digital DVI - male
24+1 pin digital DVI - female
PC 99, RoHS
