C2G 2m DVI-D™ M/M Dual Link Digital Video Cable
Quicklinx: 63MNWS00 Mfr#: 81189
Type: DVI
Length: 2m
£9.25 ex VAT
£11.10 inc VAT
This precision-engineered cable is fully compliant with the DVI standard defined by DDWG (Digital Display Working Group). The DVI-I single link configuration provides enough bandwidth for resolutions up to 2048 x 1536 pixels and allows high speed transmission up to 9.9 Gbps. Three analogue 30 AWG coaxial lines enable high speed analogue transmission.
C2G DVI cable - 2 m
DVI cable - dual link
Triple shielded
Colour-coded connectors
Length
2 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - male
PC 99, RoHS
DVI cable
Triple shielded
Shielding Material
Foil with braid
American Wire Gauge (AWG)
28
TMDS Links
Dual link
Plated Connector
Gold
Length
2 m
Connector
24+1 pin digital DVI - male
PC 99, RoHS
Type: DVI
Length: 2m
Brand: C2G
Price Range Ex VAT: 0 - 50
