DVI analog extension cables from C2G deliver the high performance, high-bandwidth interface needed for video displays of today while leaving flexibility for the products of tomorrow. It is perfect for connecting a DVI-A connector to a monitor with a VGA cable. These precision-engineered cables are fully compliant with the DVI standard as defined by DDWG (Digital Display Working Group).
- C2G VGA extension cable - 2 m
- VGA extension cable
- Technology
- Triple shielded coaxial
- Colour-coded connectors
- Length
- 2 m
- Connector
- DVI-A - female
- Connector (Second End)
- HD-15 (VGA) - male
- PC 99, RoHS
- Technology
- Shielding Material
- Foil with tinned copper braid
- American Wire Gauge (AWG)
- 28/30
- Plated Connector
- Gold
- Length
- 2 m
- Connector
- 12+5 pin analogue DVI - female
- 15 pin HD D-Sub (HD-15) - male
- PC 99, RoHS
