C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable
Quicklinx: 9MRRWS00 Mfr#: 84329
Length: 2m
Select:
£26.66 ex VAT
£31.99 inc VAT
This adapter cable is an ideal solution for connecting the DisplayPort output of a laptop to a computer monitor which accepts a DVI-D input. This cable carries a digital video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
  • Resolution Support
    1920 X 1200
  • Cable Colour
C2G 2m DisplayPort to Single Link DVI-D Adapter Cable M/M - DP to DVI - Black - DisplayPort cable - 2 m
DisplayPort cable
Shielded
Length
2 m
Connector
DisplayPort - male
Connector (Second End)
DVI-D - male
DisplayPort cable
Shielded
Shielding Material
PVC
American Wire Gauge (AWG)
30
Length
2 m
Connector
20 pin DisplayPort - male
18+1 pin digital DVI (Single-Link) - male
Length: 2m
Brand: C2G
