C2G 2m DB9 M/F Extension Cable - Beige
Quicklinx: 63TYWS00 Mfr#: 81370
Length: 2m
Type: Serial
Hurry, only 1 left in stock!
£3.49 ex VAT
£4.18 inc VAT
Don't sacrifice convenience when determining where to place your hardware. A DB9 extension cable can give you the flexibility to extend a computer peripheral wherever you need it. Each extension cable comes fully shielded to prevent unwanted EMI/RFI interference, and the fully snagless cable design delivers excellent strain relief. Connector thumbscrews provide a quick and easy connection every time. All lines are wired straight through.
  • Warranty Details
    This product carries a lifetime warranty
  • Product Colour
    Beige
C2G Extension Cable - serial extension cable - DB-9 to DB-9 - 2 m
Serial extension cable
Shielded
Molded, thumbscrews
Length
2 m
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
9 pin D-Sub (DB-9) - female
Beige
Shielded
Molded, thumbscrews
Length
2 m
Beige
Connector
RoHS
Length: 2m
Type: Serial
Brand: C2G
Stock Status: In stock
