C2G 2m Cat6 Snagless Cable Pink
Quicklinx: 6BT7WS00 Mfr#: 83590
For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
  • High-speed connectivity
    Experience seamless network performance with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support tested frequencies up to 550 MHz. This ensures optimal performance for your networking needs, whether at home or in the office.
  • Durable design
    Constructed with a PVC jacket and 24 American Wire Gauge (AWG) thickness, this patch cable is built for durability. The gold-plated RJ-45 connectors provide a reliable connection, reducing the risk of corrosion and ensuring a longer lifespan for your network infrastructure.
  • Universal compatibility
    Designed with T568B wiring scheme and compatible with PC systems, this network patch cable offers a versatile solution for connecting a wide range of devices. Its male RJ-45 connectors on both ends make it easy to connect routers, switches, and other network components.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 2 m - pink
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
2 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Pink
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
24
Plated Connector
Gold
Length
2 m
Pink
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
