C2G 2M 3.5mm STEREO AUDIO CBL M/M PC-99
Quicklinx: 63QQWS00 Mfr#: 80108
3.5mm stereo audio cables from C2G are specifically designed for quality computer audio applications. The 3.5mm cable connects the PC sound card, portable CD player or any mini-stereo audio device with 3.5mm jacks to multimedia speakers. The cable features two 29-gauge stranded conductors and a drain wire, which are tinned to resist oxidation.
C2G audio cable - 2 m
Cable
Audio cable
Shielded
Length
2 m
Connector
Mini-phone stereo 3.5 mm - male
Connector (Second End)
Colour-coded connectors, moulded
Cable Type
Audio cable
Shielded
Shielding Material
Foil
Length
2 m
Plated Connector
Nickel
Connector
RoHS
