C2G 2m 3.5mm M/M Stereo Audio Cable
Quicklinx: 63MZWS00 Mfr#: 80117
The 3.5mm stereo audio cable is specifically designed for quality computer audio applications. It attaches a PC sound card, portable CD player or any mini-stereo audio device with 3.5mm jacks to a multimedia speaker. This cable features two copper conductors and a drain wire. The conductors and drain wire are wrapped with a braided shield which prevents unwanted EMI/RFI interference. Fully snagless nickel-plated connectors provide excellent strain relief for durable use.
  • Warranty
    Lifetime
  • Colour
  • Cable Length
    2.00 Meter
C2G audio cable - 2 m
Cable
Audio cable
Shielded
American Wire Gauge (AWG)
29
Length
2 m
Connector
Mini-phone stereo 3.5 mm - male
Connector (Second End)
Stranded conductor, moulded
Cable Type
Audio cable
Shielded
29
Shielding Material
Foil
Length
2 m
Plated Connector
Nickel
Connector
RoHS
