C2G 2m 3.5mm M/F Stereo Audio Extension Cable (PC-99 Colour-Coded)
Quicklinx: 63SDWS00 Mfr#: 80100
3.5mm stereo audio cables from C2G are specifically designed for extending the distance of your existing 3.5mm audio cable. The 3.5mm audio cables connect the PC sound card, portable CD player or any mini-stereo audio device with 3.5mm jacks to multimedia speakers. The cable features two 29-gauge stranded conductors and a drain wire, which are tinned to resist oxidation.
C2G audio extension cable - 2 m
Cable
Audio extension cable
Shielded
Length
2 m
Connector
Mini-phone stereo 3.5 mm - male
Connector (Second End)
Mini-phone stereo 3.5 mm - female
Colour-coded connectors, moulded
Cable Type
Shielded
Shielding Material
Foil
Length
2 m
Plated Connector
Nickel
Connector
