C2G 2ft Locking C14 to C13 10A 250V Black
Quicklinx: D0CBWS00 Mfr#: 80701
Length: 60cm
£6.00 ex VAT
£7.20 inc VAT
There is no need for special locking sockets that take up extra space and have a higher cost. Ensure a secure power connection to critical equipment while saving both time and money using this innovative locking connector. Providing power to a server or switch is critical and a secure connection provides peace of mind. When working in a wiring closet or a cabinet space is limited and cords can easily get in the way and accidently be disconnected causing detrimental downtime. Perform maintenance tasks with confidence that the locking power cords will maintain connection without failure.
Cable install or uninstall can be very challenging when little space is available in a cabinet. The locking mechanism could not be simpler to operate. To install the cable plug it in as normal, or to unplug the cable simply grip the connector as normal but place your fingers on the release triggers and pull, the connector will come unplugged just like a normal cable.
  • Colour
  • Warranty
    Lifetime
  • Length
    2ft / 0.6m
  • Connector A
    C13
  • Connector B
    C14
C2G power cable - 60 cm
Power cable
Lockable connector
Length
60 cm
Connector
Power IEC 60320 C14
Connector (Second End)
Power IEC 60320 C13
Rated Voltage
AC 250 V
Rated Current
10 A
Power cable
American Wire Gauge (AWG)
17
Rated Voltage
AC 250 V
Rated Current
10 A
Lockable connector
Length
60 cm
198 g
Connector
Power IEC 60320 C14
Power IEC 60320 C13
UL, RoHS
Length: 60cm
Brand: C2G
Price Range Ex VAT: 0 - 50
