This adapter cable converts a Mini DisplayPort signal for viewing on a DVI-equipped display. Connect the adapter cable directly to the computer. Then use your DVI cable between the adapter and the display, and enjoy computer video content on virtually any high-definition digital audio/video display. Supports full HD resolution (1080p @ 60 Hz).
- C2G DisplayPort adapter - 21.6 cm
- DisplayPort adapter
- Length
- 21.6 cm
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- DVI-D - female
- White
- Length
- 21.6 cm
- White
- Connector
- 24+1 pin digital DVI - female
