Your basket is empty
C2G 20m TruLink® High Speed HDMI Active Optical Cable (AOC)
Quicklinx: 801XWS00 Mfr#: 82014
The TrulLink High Speed HDMI AOC provides another option from Cables To Go's portfolio of connectivity solutions for distributing high definition A/V from source to display in classrooms, conference rooms, healthcare facilities and houses of worship. Utilizing AOC technology that performs similar to traditional copper cabling, the optical fiber construction between the connectors provides optimum performance and easy installation.
C2G TruLink High Speed HDMI Active Optical Cable (AOC) - HDMI extension cable - 20 m
Cable
Length
20 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
HDMI CEC support (Consumer Electronics Control), Active Optical Cable (AOC), plenum grade, USB powered
3 years warranty
Cable Type
Length
20 m
Grey
Connector
19 pin HDMI Type A - male
Limited warranty - 3 years
