Product
C2G 20cm Mini DisplayPort Male to VGA Female Adapter Black
Quicklinx: 9MSRWS00 Mfr#: 84315
Length: 20cm
Hurry, only 1 left in stock!
£15.38 ex VAT
£18.45 inc VAT
This adapter converter is an ideal solution for converting the Mini DisplayPort output of a small laptop or tablet so that it may be connected to a computer monitor which accepts a VGA input. This adapter converter carries an analogue video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
  • Resolution Support
    Supports a resolution of 1920 x 1200
  • Colour
C2G Mini DisplayPort to VGA Adapter Converter - VGA adapter - 20 cm
VGA adapter
Length
20 cm
Connector
Mini DisplayPort - male
Connector (Second End)
HD-15 (VGA) - female
3 years warranty
VGA adapter
Length
20 cm
Connector
15 pin HD D-Sub (HD-15) - female
3 years warranty
Length: 20cm
Brand: C2G
Price Range Ex VAT: 0 - 50
