This adapter converter is an ideal solution for adapting the Mini DisplayPort output of a small laptop or tablet so that it may be connected to a HDTV or projector which accepts a HDMI input. This adapter converter carries a digital audio/video signal, supports up to a 1080p resolution and meets the requirements of high performance applications.
- C2G 20cm Mini DisplayPort to HDMI Adapter - Thunderbolt to HDMI Converter M/F - White - DisplayPort cable - 15 cm
- DisplayPort cable
- Length
- 15 cm
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- HDMI - female
- White
- Limited lifetime warranty
- DisplayPort cable
- Length
- 15 cm
- White
- Connector
- 19 pin HDMI Type A - female
