Product
C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black
Quicklinx: 9MSWWS00 Mfr#: 84323
Length: 20cm
More than 50 in stock
£10.85 ex VAT
£13.02 inc VAT
Standard delivery Delivered within 3-5 working days
This adapter converter is an ideal solution for converting the DisplayPort output of a laptop so that it may be connected to a computer monitor which accepts a VGA input. This adapter converter carries an analogue video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
  • Resolution Support
    Supports a resolution of 1920 x 1200
  • Colour
C2G DisplayPort Male to VGA Female Adapter Converter - VGA adapter - 20 cm
VGA adapter
Latched
Length
20 cm
Connector
DisplayPort - male
Connector (Second End)
HD-15 (VGA) - female
3 years warranty
VGA adapter
Latched
Length
20 cm
Connector
20 pin DisplayPort - male
15 pin HD D-Sub (HD-15) - female
3 years warranty
Length: 20cm
Brand: C2G
Price Range Ex VAT: 0 - 50
