C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black
Quicklinx: 9MSTWS00 Mfr#: 84321
Length: 20cm
£15.02 ex VAT
£18.02 inc VAT
This adapter converter is an ideal solution for adapting the DisplayPort output of a laptop so that it may be connected to a computer monitor which accepts a DVI-D input. This adapter carries a digital video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
  • Resolution Support
    1920 X 1200
  • Cable Colour
C2G DisplayPort to DVI-D Adapter Converter - Single Link DVI-D Video Adapter M/F - Black - video adapter - 20 cm
Video adapter
Latched
Length
20 cm
Connector
DisplayPort - male
Connector (Second End)
DVI-D - female
3-year warranty
Video adapter
Latched
Length
20 cm
Connector
20 pin DisplayPort - male
18+1 pin digital DVI (Single-Link) - female
3-year warranty
Length: 20cm
Brand: C2G
Price Range Ex VAT: 0 - 50
