This adapter converts a DisplayPort signal for viewing on a VGA-equipped display. Connect the adapter directly to the PC. Then use your VGA cable between the adapter and the display, and enjoy PC video content on virtually any VGA display. Features 20cm dongle-style adapter, nickel-plated DisplayPort connector, molded VGA connector, 28 AWG copper wire, Aluminum shielding to protect against EMI/RFI.
- C2G DisplayPort 1.1 to VGA Adapter Cable - VGA adapter - 20 cm
- VGA adapter
- Technology
- Shielded
- Molded
- Length
- 20 cm
- Connector
- DisplayPort - male
- Connector (Second End)
- HD-15 (VGA) - female
- Black
- Limited lifetime warranty
- VGA adapter
- Technology
- Shielded
- Shielding Material
- Aluminium foil
- American Wire Gauge (AWG)
- 30
- Plated Connector
- Nickel
- Molded
- Length
- 20 cm
- Black
- Connector
- 20 pin DisplayPort - male
- 15 pin HD D-Sub (HD-15) - female
- DisplayPort 1.1
