The USB-C to VGA Adapter Cable provides a fast and reliable connection between a USB Type C enabled Chromebook, laptop, tablet or other device and a monitor, projector or other display with a VGA input – making it an ideal solution for the office, work space applications or home use. This adapter utilises the audio/video capabilities built into USB Type-C ports to feed a video signal to the connected display and supports up to a 1920x2100 at 60Hz resolution, allowing it to deliver a high-quality video image. Additionally, the USB-C connector has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. The cable form factor of this adapter provides a simple and convenient one-cable solution that eliminates the need for a separate adapter or additional cabling.
- C2G 2.7m (9ft) USB C to VGA Adapter Cable - Video Adapter - Black - external video adapter - black
- External video adapter
- Bus Type
- USB-C
- Max Resolution
- 1920 x 1200
- VGA (male connector)
- Length
- 2.7 m
- Enclosure Colour
- Black
- 3-year warranty
- Bus Type
- USB-C
- Max Resolution
- 1920 x 1200 at 60 Hz
- Plug and Play, RoHS 2 (2011/65/EU)
- Length
- 2.7 m
- Enclosure Colour
- Black
- Limited warranty - 3 years
- 0 °C
- 45 °C
