C2G 1m USB A Male to Lightning Male Sync and Charging Cable
Quicklinx: 9Y4XWS00 Mfr#: 86051
Length: 1m
Colours:
£9.60 ex VAT
£11.52 inc VAT
The USB A Male to Lightning Male sync and charging cable is perfect for downloading data from or uploading data to the latest generation of Apple iPad, iPhone or iPod devices while also allowing the device to be charged. The cable construction and design make it ideal for travel. This cable is great as a replacement or a spare to sync and charge an Apple device at home, in the office or on the go. This cable is MFi certified for compatibility with Apple products.
  • Colour
    White
  • Certification
C2G USB A Male to Lightning Male Sync and Charging Cable - Lightning cable - Lightning / USB - 1 m
Cable
Length
1 m
White
Connector
Lightning - male
Connector (Second End)
USB - male
Sync and charge
Apple iPad Air; iPad mini; iPad mini 2; iPad with Retina display (4th generation); iPhone 5, 5c, 5s; iPod nano (7G); iPod touch (5G)
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Jacket Material
PVC
Impedance
100 Ohm
Length
1 m
Plated Connector
Nickel
Sync and charge
White
Connector
Apple Lightning - male
4 pin USB Type A - male
MFI
Limited warranty - lifetime
Apple iPad Air , Apple iPad mini , Apple iPad mini 2 , Apple iPad with Retina display (4th generation) , Apple iPhone 5, 5c, 5s , Apple iPod nano (7G) , Apple iPod touch (5G)
Length: 1m
Brand: C2G
Price Range Ex VAT: 0 - 50
