Product
C2G 1m USB 3.0 (USB 3.1 Gen 1) USB-C to USB-Micro B Cable M/M
Quicklinx: CHP2WS00 Mfr#: 88862
Length: 1m
2 in stock
£10.87 ex VAT
£13.04 inc VAT
Standard delivery Delivered within 3-5 working days
This USB 3.0 (USB 3.1 Gen 1) USB-C to USB-Micro B cable is the perfect solution for connecting a smartphone, tablet, or other device that has a USB-Micro B port to a computer, tablet or other device that has a USB Type-C port for USB 3.0 (USB 3.1 Gen 1) communication. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 3.0 (USB 3.1 Gen 1) cable and differentiated from other cables which may support a different feature set. The USB Type-C connector is smaller than traditional USB connector and features a symmetrical design which allows it to be easily connected on the first try. Additionally, the durability of the USB Type-C connector allows for up to 10,000 connection cycles. This cable supports a data rate up to 5Gbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging.
  • Warranty
    Lifetime
  • Colour
  • Length
    1 meter
C2G USB-C cable - 1 m
USB-C cable
Sync and charge, colour-coded connectors, nickel plated shell
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
10 pin Micro-USB Type B - male
USB 3.0/ USB 3.1
USB-C cable
American Wire Gauge (AWG)
24/30
Plated Connector
Gold
Length
1 m
Connector
24 pin USB-C - male
USB 3.0/ USB 3.1
Length: 1m
Brand: C2G
Price Range Ex VAT: 0 - 50
