C2G 1m USB 2.0 A Right Angle Male to Micro-USB Right Angle Male
Quicklinx: 9Y4LWS00 Mfr#: 81704
£4.30 ex VAT
£5.16 inc VAT
Connect to mobile phones, GPS systems, PDAs, OTG devices and digital cameras by using the micro-USB connection on your computer or other USB device. The micro-USB connector is smaller and thinner than the previous USB Mini-b standard while offering better performance. Its small right angle form factor is ideal for today's compact portable devices while easily transferring data or charging your device at a transfer speed up to 480 Mbps. This cable is compliant with USB 2.0 specifications and the On-The-Go supplement.
  • Connector 1
    (1) USB-A Male
  • Connector 2
    (1) USB Micro-B Male
  • Warranty
    Lifetime warranty
C2G USB 2.0 A Right Angle to Micro-USB B Right Angle Cable - USB cable - 1 m
USB cable
90° connector, right-angled connector, sync and charge, USB On-The-Go
Length
1 m
Connector
5 pin Micro-USB Type B - male
Connector (Second End)
4 pin USB Type A - male
USB cable
Length
1 m
Connector
Brand: C2G
Price Range Ex VAT: 0 - 50
