Thunderbolt 3 brings lightning-speed data transfer, 4K at 60Hz video support, high bit depth audio, and power delivery up to 100W. Deliver up to 20Gbps to or from a Thunderbolt 3 enabled port. Whether uploading or downloading data, this cable is an ideal solution to transfer large amounts of information such as high-resolution photos for editing or storage, 3D models for video game authoring or HD video for editing. Whether you’re desk-based or on-the-road, this lightweight, portable one-cable solution ensures that your Thunderbolt 3 equipped laptop, smartphone, or tablet is fully charged and ready to go whilst displaying ULTRA HD video content, transferring files, or streaming audio. Deliver up to 100W of charging power to or from the connected device with smart power delivery. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port.
- C2G 1m Thunderbolt 3 Cable (20Gbps) - Thunderbolt Cable 4K - Black - Thunderbolt cable - 24 pin USB-C to 24 pin USB-C - 1 m
- Thunderbolt cable
- 4K support, sync and charge
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Rated Voltage
- 30 V
- Thunderbolt 3
- Black
- 3-year warranty
- Thunderbolt cable
- American Wire Gauge (AWG)
- 30
- Rated Voltage
- 30 V
- Length
- 1 m
- Black
- 52.6 g
- Connector
- Thunderbolt 3
- 3-year warranty
