Brand
C2G 1m SC/SC LSZH Duplex 50/125 Multimode Fibre Patch Cable - Orange
Quicklinx: 6C1ZWS00 Mfr#: 85303
Cost-effective solution that provides higher bandwidth and transmission rates and supports longer distances with lower loss than 62.5/125 fibre. Specifically designed for use with today's narrower aperture components, this cable is fully compatible with multimode applications. The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures. This reduces the amount of harmful toxic and corrosive gases that cabling made with plastic materials would otherwise emit into the air during combustion. This construction makes LSZH cables ideal for use where the protection of people and equipment from harmful corrosive gases is absolutely critical. The patented injection moulding process provides each connection greater durability in resisting pulls, strains and impacts from cabling installs. Each cable is 100% optically inspected and tested for insertion loss before you receive it. A pull-proof jacket design surrounds the popular 50/125 multimode fibre, immune to electrical interference.
  • Warranty Details
    This product carries a lifetime warranty
  • Jacket Rating
  • Connector Durability
  • Jacket Design
C2G Low-Smoke Zero-Halogen - patch cable - 1 m - orange
Patch cable
Fibre optic
Type of Fibre Optics
Multimode
Length
1 m
Core / Cladding Diameter
50 / 125 micron
Connector
2 x SC multi-mode - male
Connector (Second End)
Orange
Network Cable Type
Patch cable
Fibre optic
Multimode
Jacket Material
Low Smoke Zero Halogen (LSZH)
Fibre Qty
2
50 / 125 micron
Length
1 m
Orange
Connector
RoHS
