C2G 1m Pro-Audio XLR Male to XLR Female Cable
Reduced Price - Whilst Stocks Last!
Quicklinx: 67WBWS00 Mfr#: 80377
Use this XLR to XLR cable to connect unbalanced sources to balanced XLR inputs. This pro-audio cable is made from 22 AWG twisted pair audio cable under an aluminum foil shield and 60% copper braid for maximum shielding from noise. The highly flexible 7 mm PVC jacket reduces the risk of the cable kinking and damaging the conductors.
Bright nickel plating on solid brass connectors resists wear from reconfiguring and moving equipment from one venue to another. Spring strain relief on the plug and a chuck strain relief inside the XLR reduce the effects of age on the solder joints and contacts.
C2G Pro-Audio audio cable XLR3 to XLR3 - 1 m
Cable
Audio cable
Shielded foiled twisted pair (SFTP)
American Wire Gauge (AWG)
22
Length
1 m
Connector
XLR3 - male
Connector (Second End)
XLR3 - female
Cable Type
Audio cable
22
Jacket Material
Flexible PVC
Shielding Material
Foil with copper braid
Length
1 m
Plated Connector
Nickel
Connector
3 pin XLR - male
3 pin XLR - female
RoHS
