C2G 1m Pro-Audio 1/4in TRS Male to 1/4in TRS Male Cable
Quicklinx: 67WLWS00 Mfr#: 80388
Type: Audio
Length: 1m
£5.02 ex VAT
£6.02 inc VAT
Use this 1/4in to 1/4in cable to connect unbalanced line outputs to unbalanced line inputs. This pro-audio cable is made from 22 AWG twisted pair audio cable under an aluminium foil shield and 60% copper braid for maximum shielding from noise. The highly flexible 7mm PVC jacket reduces the risk of the cable kinking and damaging the conductors. Bright nickel plating on solid brass connectors resists wear from reconfiguring and moving equipment from one venue to another. Spring strain relief on the 1/4in plug reduces the effects of age on the solder joints and contacts.
  • Warranty Details
    This product carries a lifetime warranty
  • Maximum Sheilding
    Made from 22 AWG twisted pair audio cable under an aluminium foil shield and 60% copper braid for maximum shielding from noise
  • Cable Flexibility
    Highly flexible 7mm PVC jacket reduces the risk of the cable kinking and damaging the conductors
C2G Pro-Audio audio cable - 1 m
Cable
Audio cable
Shielded foiled twisted pair (SFTP)
American Wire Gauge (AWG)
22
Length
1 m
Connector
Mono jack - male
Connector (Second End)
Mono jack - male
Cable Type
Audio cable
22
Jacket Material
PVC
Shielding Material
Foil with copper braid
Length
1 m
Plated Connector
Nickel
Connector
Phone mono 6.35 mm - male
RoHS
Type: Audio
Length: 1m
Brand: C2G
