C2G 1m Premium Shielded HD15 SXGA M/F Monitor Extension Cable
Quicklinx: 63NJWS00 Mfr#: 81096
Gain maximum flexibility when positioning your VGA card and monitor with Premium Shielded VGA extension cables from C2G. Constructed from premium grade shielded video cable, this cable uses a combination of coax and twisted-pair to accommodate cable runs up to 30.48 meters away, without any of the typical distortion problems associated with extended length cabling runs. These cables are designed to hold the signal over greater distances without the need for boosting or reconditioning. These premium SXGA monitor extension cables are ideal for video presentations, classroom environments, POS, server rooms, or just for organizing your work area for maximum comfort and efficiency.
C2G Premium VGA extension cable - 1 m
VGA extension cable
Shielded twisted pair coaxial
Length
1 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - female
RoHS
VGA extension cable
Length
1 m
Connector
15 pin HD D-Sub (HD-15) - female
RoHS
