This cable is an ideal solution for connecting the Mini DisplayPort output of a small laptop or tablet to a computer monitor which accepts a Mini DisplayPort input. This cable carries a digital audio/video signal. Support of a High Bit Rate (HBR) bandwidth means that this cable can carry up to a 4k resolution. Built to DisplayPort 1.2 standards, this cable meets the requirements of high performance applications.
Resolution Support
Supports up to 4K resolution -
DisplayPort Specification
DisplayPort 1.2 Standards -
Cable Colour
White
- C2G 1m Mini DisplayPort Cable 4K UHD M/M - White - DisplayPort cable - 1 m
- DisplayPort cable
- Length
- 1 m
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- White
- Limited lifetime warranty
- DisplayPort cable
- Length
- 1 m
- White
- Connector
- DisplayPort 1.2
