C2G 1m European Laptop Power Cord (CEE 7/7 to IEC 60320 C5)
Quicklinx: 98PJWS00 Mfr#: 80606
£3.07 ex VAT
£3.68 inc VAT
Replace your overused or misplaced power cable, or just get some extra cords for convenience. This power cord is designed to work with laptops that use a 3-slot power cord. Plus this heavy duty 18 AWG cord features a fully moulded design for maximum durability and long life. The female connector, often called a Clover Leaf connector, plugs directly into the device while the male connector plugs into a standard outlet.
  • Product Use
    European replacement power cord for many laptops
  • Warranty Details
    This product carries a lifetime warranty
  • Connector Information
    The female connector is often called a Clover Leaf connector
C2G Laptop Power Cord - power cable - IEC 60320 C5 to power CEE 7/7 - 1 m
Power cable
Molded
Length
1 m
Europe
Connector
Power IEC 60320 C5
Connector (Second End)
Power CEE 7/7 - male
Rated Voltage
AC 250 V
Power cable
American Wire Gauge (AWG)
18
Rated Voltage
AC 250 V
Molded
Length
1 m
Europe
Connector
Power IEC 60320 C5
