C2G 1m DisplayPort Male to VGA Male Adapter Cable - Black
Quicklinx: 9MRTWS00 Mfr#: 84331
Length: 1m
Select:
£7.22 ex VAT
£8.66 inc VAT
This adapter cable is an ideal solution for connecting the DisplayPort output of a laptop to a computer monitor which accepts a VGA input. This cable carries an analogue video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
  • Colour
  • Resolution
    Supports up to a 1920x1200 resolution
C2G 1m DisplayPort to VGA Adapter Cable - DP to VGA - Black - DisplayPort cable - 1 m
DisplayPort cable
Length
1 m
Connector
DisplayPort - male
Connector (Second End)
HD-15 (VGA) - male
DisplayPort cable
Length
1 m
Connector
20 pin DisplayPort - male
Length: 1m
Brand: C2G
Price Range Ex VAT: 0 - 50
