Use this DisplayPort to DVI cable to connect a DisplayPort source directly to a DVI monitor or display. The passive design will support a 1920 x 1080 resolution up to 3 metres. It is VESA-compliant with transparent operation which will auto-calibrate and configure the signal for minimal configuration. Great for applications when you want to connect a newer laptop or desktop to a DVI-enabled display.
- C2G DisplayPort 1.1 to DVI-D Cable - DisplayPort cable - 1 m
- DisplayPort cable - dual link
- Technology
- Shielded
- Molded, thumbscrews
- Length
- 1 m
- Connector
- DisplayPort - male
- Connector (Second End)
- DVI-D - male
- Black
- Limited lifetime warranty
- DisplayPort cable
- Technology
- Shielded
- Shielding Material
- Foil
- American Wire Gauge (AWG)
- 28
- TMDS Links
- Dual link
- Plated Connector
- Nickel
- Length
- 1 m
- Black
- Connector
- 20 pin DisplayPort - male
- 24+1 pin digital DVI - male
- DisplayPort 1.1
