High quality 75-Ohm BNC cable from C2G is ideal for video applications. Manufactured from coax cable and nickel plated BNC connectors. A molded PVC strain relief protects the cable from wear over time.
- C2G video cable - 1 m
- Cable
- Video cable
- Technology
- Double shielded coaxial
- American Wire Gauge (AWG)
- 22
- Length
- 1 m
- Connector
- BNC - male
- Connector (Second End)
- BNC - male
- RG-59
- Moulded
- Cable Type
- Video cable
- Technology
- 22
- Jacket Material
- PVC
- Shielding Material
- Foil with copper braid
- Impedance
- 75 Ohm
- RG-59
- Length
- 1 m
- Plated Connector
- Nickel
- Moulded
- Connector
- BNC - male
- BNC - male
- RoHS
