Absolutely brilliant solution to make wiring and cable installations clean and well organized. The cable clamp allows you to easily mount cable bundles to the wall, ceiling or any surface desired. The cable clamp has a self-adhesive pad on the back that makes toolless installation a breeze.
- C2G cable clips
- Product Type
- Cable clips
- Packaged Quantity
- 50 (specifications are for single item)
- Black
- 1-year warranty
- Packaged Quantity
- Product Type
- Cable clips
- Enclosure Colour
- Black
- Self-adhesive
- Limited warranty - 1 year
