C2G 16 AWG 1-to-2 Power Cord Splitter 1.8m
Quicklinx: CXPNWS00 Mfr#: 80631
Replace your overused or misplaced power cable, or just manage your power more efficiently. This handy cable features a male 3-prong plug which splits to two female 3-prong shrouds. Simply plug the power cord's male prong into a standard outlet, and you're ready to power multiple electronic devices. Saves space by eliminating extra cords, and keeps your surge strip and UPS outlets from being blocked by bulky AC transformers. Ideal for use in compact workplaces or home offices where there is limited space for electronic equipment. Plus this heavy duty 16 AWG cord features a fully moulded design for maximum durability and long life.
  • Efficient power distribution
    The 16 AWG 1-to-2 Power Cord Splitter by C2G is designed to distribute power from a single source to two devices efficiently, ensuring your PC setup is powered effectively without the need for multiple power outlets.
  • High compatibility
    Featuring a power IEC 60320 C14 connector on one end and two IEC 60320 C13 connectors on the other, this power splitter is compatible with a wide range of PC power supplies, making it a versatile addition to any setup.
  • Durable design
    Constructed with high-quality 16 American Wire Gauge (AWG) cable, this power splitter is built to last, providing a reliable power solution for your computing needs.
C2G 16 AWG 1-to-2 Power Cord Splitter - power splitter - IEC 60320 C14 to power IEC 60320 C13 - 1.8 m
Power splitter
Molded
Length
1.8 m
Connector
Power IEC 60320 C14
Connector (Second End)
2 x power IEC 60320 C13
Power splitter
16
Molded
Length
1.8 m
Connector
Power IEC 60320 C14
