C2G 15m SC-SC 50/125 OM2 Duplex Multimode PVC Fibre Optic Cable (LSZH) - Orange
Quicklinx: 9C9MWS00 Mfr#: 85477
Length: 15m
Colour: Orange
£18.75 ex VAT
£22.50 inc VAT
Cost-effective solution that provides higher bandwidth and transmission rates and supports longer distances with lower loss than 62.5/125 fibre. Specifically designed for use with today's narrower aperture components, this cable is fully compatible with multimode applications.
The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures.
This reduces the amount of harmful toxic and corrosive gases that cabling made with plastic materials would otherwise emit into the air during combustion. This construction makes LSZH cables ideal for use where the protection of people and equipment from harmful corrosive gases is absolutely critical.
The patented injection moulding process provides each connection greater durability in resisting pulls, strains and impacts from cabling installs.
Each cable is 100% optically inspected and tested for insertion loss before you receive it. A pull-proof jacket design surrounds the popular 50/125 multimode fibre, immune to electrical interference.
Connector 1: (1) SC Male
Connector 2: (1) SC Male
Length: 15m
Colour: Orange
Brand: C2G
Price Range Ex VAT: 0 - 50
