C2G 15m Cat6 550 MHz Snagless Patch Cable - Green
Quicklinx: 6BQQWS00 Mfr#: 83433
For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily colour-coded your network installation. Each cable is individually labelled with the length for ease of use.
  • Warranty
    Lifetime
  • Colour
    Green
  • Length
    15 meter
C2G Cat6 550MHz Snagless Patch Cable - patch cable - 15 m - green
Patch cable - CAT 6
Wiring Scheme
T568B
Molded, snagless, stranded
Length
15 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Green
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Gold
Length
15 m
Green
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
