Your basket is empty
C2G 15m 3.5mm Right-Angled Stereo Audio Cable
Call Your Account Manager For C2G Deals!
Quicklinx: 7B8WWS00 Mfr#: 80142
The C2G "Value Series" stereo right angle audio cable is specifically designed to provide a brilliant audio experience. It connects a PC sound card, portable CD player or any mini-stereo audio device to a multimedia speaker. This cable features two copper conductors and a drain wire. The conductors and drain wire are wrapped with an aluminum Mylar shield which prevents unwanted EMI/RFI interference. Fully molded nickel-plated connectors provide excellent strain relief for durable use.
C2G Value Series audio cable - 15 m
Cable
Audio cable
Shielded
Length
15 m
Connector
Stereo mini jack - male
Connector (Second End)
90 degree connector, right-angled connector
Cable Type
Audio cable - 90° connector, right-angled connector
Shielded
Shielding Material
Aluminium mylar
Length
15 m
Plated Connector
Nickel
Moulded
Connector
Mini-phone stereo 3.5 mm - male
RoHS
Limited warranty - lifetime
