C2G 15cm Mobile Device USB Micro B to USB Device OTG Adapter Cab
Quicklinx: 9CRFWS00 Mfr#: 82410
Length: 15cm
£4.18 ex VAT
£5.01 inc VAT
The 15 cm Mobile Device USB Micro-B to USB Device OTG adapter cable is the perfect solution for expanding the capabilities of an OTG enabled tablet, smartphone or other mobile device by directly connecting a USB device such as a USB flash drive for additional storage or a USB keyboard and mouse for additional control. Connect a USB hub to this adapter to further expand the capabilities of the mobile device by connecting multiple USB devices. USB OTG technology makes this connection easy and does not require a driver, software or lengthy setup time. Simply connect the adapter to the Micro-B port on an OTG enabled mobile device, connect the USB device directly to the USB A port on the adapter and the two devices are ready to be used together.
C2G Mobile Device USB Micro-B to USB Device OTG Adapter Cable - USB adapter - USB to Micro-USB Type B - 15 cm
USB adapter
Double shielded
Length
15 cm
Connector
4 pin USB Type A - male
Connector (Second End)
5 pin Micro-USB Type B - female
USB adapter
Double shielded
American Wire Gauge (AWG)
28
Length
15 cm
Connector
Length: 15cm
Brand: C2G
Price Range Ex VAT: 0 - 50
