This adapter converter is an ideal solution for adapting the Mini DisplayPort output of a small laptop or tablet so that it may be connected to a computer monitor which accepts a DisplayPort input. This adapter converter carries a digital audio/video signal and supports up to a 4k resolution and meets the requirements of high performance applications.
- C2G 15cm Mini DisplayPort to DisplayPort Adapter Converter 4K UHD - Mini DP Male to DP Female - Black - DisplayPort cable - 15 cm
- DisplayPort cable
- Length
- 15 cm
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- DisplayPort - female
- Black
- Limited lifetime warranty
- DisplayPort cable
- Length
- 15 cm
- Black
- Connector
- 20 pin DisplayPort - female
- DisplayPort 1.2
