C2G 15cm Mini DisplayPort Male to DisplayPort Female Adapter Cable -  Black
Quicklinx: 9MSKWS00 Mfr#: 84303
Colours:
This adapter converter is an ideal solution for adapting the Mini DisplayPort output of a small laptop or tablet so that it may be connected to a computer monitor which accepts a DisplayPort input. This adapter converter carries a digital audio/video signal and supports up to a 4k resolution and meets the requirements of high performance applications.
  • Resolution Support
    Supports up to 4K resolution
  • Cable Colour
C2G 15cm Mini DisplayPort to DisplayPort Adapter Converter 4K UHD - Mini DP Male to DP Female - Black - DisplayPort cable - 15 cm
DisplayPort cable
Length
15 cm
Connector
Mini DisplayPort - male
Connector (Second End)
DisplayPort - female
DisplayPort cable
Length
15 cm
Connector
20 pin DisplayPort - female
DisplayPort 1.2
