C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8WS00 Mfr#: 81656
Length: 12m
£15.77 ex VAT
£18.92 inc VAT
The TruLink USB 2.0 Active Extension Cable is perfect when you need extra distance; this cable will extend the reach of your USB 2.0 cable or device 12m (40'). The USB active extension cable actively buffers the incoming and outgoing signals to ensure compliance with the USB 2.0 specification for electrical and timing minimums. Both low and high speed USB devices will function equally well with this cable. Great for extending the reach to your USB devices.
C2G TruLink USB 2.0 Active Extension Cable - USB extension cable - USB to USB - 12 m
USB extension cable
Active cable (signal regeneration)
Length
12 m
Connector
4 pin USB Type A - female
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
1-year warranty
USB extension cable
Length
12 m
Connector
USB / USB 2.0, Plug and Play, RoHS
1-year warranty
Length: 12m
Brand: C2G
Stock Status: In stock
