The Select Standard Speed HDMI Cable provides a reliable connection up to a distance of 30 feet (10 metres) for home theatre, desktop and commercial audio video applications requiring standard speed HDMI capabilities and video resolutions up to 1080i. The CL2 rated cable jacket is designed to meet the requirements for in-wall installations. The Ethernet capabilities of the cable enable users to connect multiple Ethernet-enabled devices through a single Ethernet connection. This fully-functional cable is tested to perform at industry standards and backed by a lifetime warranty.
- C2G 10m Select Standard Speed HDMI Cable with Ethernet - HDMI with Ethernet cable - 10 m
- Cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 28
- Length
- 10 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- Limited lifetime warranty
- Cable Type
- Technology
- Shielded
- 28
- Jacket Material
- PVC
- Shielding Material
- Aluminium foil with braid
- Impedance
- 100 Ohm
- Length
- 10 m
- Plated Connector
- Gold
- Black
- Connector
- 19 pin HDMI Type A - male
- UL
- Limited warranty - lifetime
