Cost-effective solution that provides higher bandwidth and transmission rates and supports longer distances with lower loss than 62.5/125 fibre. Specifically designed for use with today's narrower aperture components, this cable is fully compatible with multimode applications. The patented injection moulding process provides each connection greater durability in resisting pulls, strains and impacts from cabling installs.
- C2G patch cable - 10 m - orange
- Patch cable
- Technology
- Fibre optic
- Type of Fibre Optics
- Multimode
- Length
- 10 m
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- 2 x LC multi-mode - male
- Connector (Second End)
- Orange
- Limited lifetime warranty
- Network Cable Type
- Patch cable
- Technology
- Fibre optic
- Multimode
- Jacket Material
- PVC
- Fibre Qty
- 2
- 50 / 125 micron
- Length
- 10 m
- Orange
- Connector
- RoHS, OFNR
