High-speed IEEE-1284 compliant cable from C2G ensures you realize the added speed and two way communications offered by your newer printers, HP tape drives, Iomega devices, scanners and more. This advanced technology, which defines high-speed, bi-directional communications between PC and peripheral, requires both high quality connectors and a specialized wire-type to handle the increased data rates.
- C2G parallel cable - 10 m
- Parallel cable
- Technology
- Double shielded twisted pair
- Molded
- Length
- 10 m
- Connector
- DB-25 - male
- Connector (Second End)
- DB-25 - male
- RoHS
- Parallel cable
- Technology
- Shielding Material
- Foil with braid
- Molded
- Length
- 10 m
- Connector
- 25 pin D-Sub (DB-25) - male
- IEEE-1284, RoHS
